2001-2003 Honda Odyssey erratic idle.
kazbanz, Nov 12, 10:47pm
Guys I've got a bit of a headscratcher for you all.
2.3l Honda Odyssey had an an erratic idle in neutral/parkwhen it was warmed up.
It would idle at 700 then go up to 1200 in fairly even cyclic manner.
It was sent to our mechanic along with another identical vehicle that ran perfectly.No air leaks found,throttle body swapped with no effectand then EGR valve swapped and BINGO. nice smooth even idle. Problem solved and replacement EGR fitted
Fast forward a weekand a happy customer took delivery.
around 150=200km laterthe idle issue is back with a vengance.
NOW its idle varies between 700 and 2500 rpm and its doing it both in neutral and drive.
It DRIVES perfectly once up off of idle.
What on earth could have happened! what would you think would be the fault!
grangies, Nov 12, 11:14pm
paul271, Nov 12, 11:22pm
Idle speed control motor! Or possibly coolant temp sensor faulty! Has it been scanned to see what the engine is doing while faulting!
kazbanz, Nov 12, 11:39pm
It was scanned the first time .Codes cleared due to the old Jap import dead battery syndrome. Once the egr was fitted no new codes came up and it ran perfectly. It drove Auckland to Tauranga with NO problems and of course the issue reared its ugly head today
lugee, Nov 13, 12:12am
Inspect/clean/replace the IACV.
kazbanz, Nov 13, 12:52am
any of you lot based in Tauranga--I know Bob 1120 was from memory
robinm1, Nov 13, 2:38am
Tony, Bob has sherson auto centre in Tauranga
stoneymeadows, Nov 13, 3:31am
x1
Try blocking off EGR valve temporarly with a plate just in case you got a dud valve.
motorway, Nov 13, 4:29am
Been collectively ripping our thinning hair out with this very issue over the last 2 weeks, all of the above rectifies it for a while but then the bastard Boomerangs.
Get back to you next week.
carmedic, Nov 13, 5:53am
I know you put a new throttle body on it but did you try adjusting the TPS!
It sounds very simplistic I know, but I??
bigfatmat1, Nov 13, 6:01am
air lock in the cooling system. or a air leak
carstauranga001, Nov 13, 6:18am
I've txted kaz mate. All good
antwerp87, Nov 13, 9:31am
Check out your PCV valve. If its the F22/F23 motor its a likely cause
kazbanz, Nov 13, 7:54pm
In all honesty I don't know. I suspect it was a case of -"that fixed it" so look no further
motorway, Nov 16, 5:20am
Blocked the EGR valve off, no problems for 4 days now.
guest, Oct 24, 6:22am
IACV
