P11 primera auto trans
hurricaneken, Nov 17, 10:09am
does anyone know if the auto trans is filled by dipstick tube or do they have a fill plug, its just standard 4 speed auto sr18de not cvt, thanks.
im going to change the trans oil and filter tomorrow.
shane038, Mar 13, 1:40am
Filled through the dipstick tube I'm afraid slow process. Beware changing the filter! 90% of the time they dont need changing, and if you do you more thn likely will have to take the valve body out as one of the filter bolts is an alignment bolt that has a nut on the upper side of the valve body, which when the bolt is undone you cant get back on :(
