Transmission problem with honda odyssey 98
mikynz, Jan 25, 11:24am
recently, I hear grinding noise at around 90-100km/h. noise start when I step off accel. does anyone know price range to fix in east auckland!
jasongroves, Jan 25, 11:38am
Impossible to give a price without a diagnosis 1st I'm afraid.
Basic checks you can do yourself include checking the transmission fluid level and condition.
Is there any service history for the transmission!
racetoy, Jan 25, 9:06pm
is it 2wd or 4wd !
sallyjoy, Jan 25, 10:31pm
trans is real common weak point on these cars supposedly. Ours started making funny noises so i took it to trans shop. $3000 and all better. Sooner you fix it the better.
mikynz, Jan 26, 12:48am
it is 2WD and no problem with fluid level, I suspect higher gear has problem because no problem with driving under 80km/h.
sparkyvnz, Feb 6, 6:51am
it sounds like it could have dead diff bearings quite common on the 2wd honda odyessy as thay use a to small of a bearing on one side.or the roller bearing has the hardning gone on the hub for forth gear or 3rd i kant quite remember what one!
