Triumph Bonneville Motorcycle Question
hurricane-x75, May 17, 1:44am
So if the late 1970s and early 1980s Bonnys have electronic ignition which is either located behind the sidecover or under the seat, what is under the old points cover!
sr2, May 17, 2:13am
From memory a crank position sensor. Try Google, there is a wealth of info on old Triumps out there.
neell, May 17, 6:41am
sr2 is correct. On the end of the exhaust cam there is a rotor with 2 little magnets on it. This spins and triggers the electronic unit. The plate the holds the sensors has slotted mounting holes allowing adjustment of the timing.
