Cefiro - drivers headlight - intermittent off
#MessagePosted
#1
Hi all
Got a 94 Cefiro - the only issue is the drivers headlight goes out - everytime this has happened over the last 18 mths the mechanic sticks in a new bulb $25 and I am away. Then someone points it out and back to mechanic and new bulb. It has WOF etc - but now it is going off after maybe 20 mins driving - and of course I only "see" the problem on my way home from work. Has been back and forth and in Nov I asked mech to take to auto elec - who could find nothing wrong. Happened again the same nite - back to auto elec who said it STILL looked OK and the light was working.
Have checked fuses etc and the light itself is undamaged and all other electrics in car are 100%.
Obviously the auto elec needs to spend more time with it but any clues! It is BAD when you stand there and say "it goes off" and he says "it's working OK now".
TIA
Driver_groovebox
Feb 20, 2012, 10:37 pm
#2http://www.trademe.co.nz/motors/car-parts-accessories/performance/bulbs/auction-450360259.htm
maybe they buying cheap bulbs
Driver_next-to-normal
Feb 20, 2012, 11:44 pm
#3Check the plug that connects to the bulb, most likely replace it.
Driver_jono2912
Feb 21, 2012, 1:11 am
#4switch is a common failure on these.
Driver_bigfatmat1
Feb 21, 2012, 7:13 am
#5Yes but with Nissan if problem is switch its the left hand headlight that dies not the drivers side.
As far as I know.
sounds like dirty earth shorting out the bulb.
Driver_the_don_61
Feb 21, 2012, 10:38 am
#6
If it's the same as a C22 van I had once the headlights are not on the same feed, the switch has two sets of contacts and each headlight is on its own circuit. Mine had one headlight out and it was the switch at fault.
Driver_rob_man
Feb 21, 2012, 12:32 pm
#7what a silly comment either headlight could fail if it was the switch. the contacts are both the same the bulbs are both the same ect y would only the left fail!
Driver_bigfatmat1
#8Thanks - I had mentioned the switch - but the auto elec said it "seemed" fine. As I say - unless he can see it failing it is hard to describe.
Driver_groovebox
Feb 21, 2012, 10:07 pm
Leave a comment No registration required to post on this thread
Comment *
Name
Similar topics
TopicRepliesLast post
Trucks and bad drivers as per a tv show121 day, 22 hours
Any tricks to removing key scratches off car paint105 days, 16 hours
Mazda familia headlight problem65 days, 18 hours
Is any b pillar damage a right off?125 days, 18 hours
Thanks to the car drivers that didn't stop.856 days, 22 hours
