Oil pressure switch location 1994 Honda Odyssey?
porteous1, May 12, 6:47am
The oil light has just started to come on in this vehicle - who can tell me where to locate the oil pressure switch!I want to get on to it first thing Monday so if I know exactly where to start it woiuld be helpful.Also - if the switch is OK then I may have to replace the olil pump - can I get to it if I remove the sump on this model!Any assistance appreciated.
a18a, May 12, 6:50am
in the back of the block under the intake manifold.
a.woodrow, May 12, 6:58am
Time for a silly question - Have you checked the oil level and when was the last service!
porteous1, May 12, 8:37am
OIL LEVEL OK - LAST SERVICE NOT SURE-HAVEN'T HAD IT LONG
porteous1, May 12, 8:38am
cheers!
mugenb20b, May 13, 3:48am
How did you get on!
a.woodrow, May 13, 4:03am
I would think that if the oil light is "just starting to come on" that you might want to try a service before you look too much further.
mugenb20b, May 13, 4:04am
Or clean the oil pick up screen.
a.woodrow, May 13, 4:08am
Aye another good Idea. In my experience a dodgy pressure sensor usually just outright fails and the light stays on. In this case it sounds like it's actually caused by low oil pressure, and as I don't believe I've ever replaced a honda oil pump in my life, nor ever heard of one failing I would suspect starvation caused by dirty old oil or a blocked pick up
