Auto transmission slipping. please help
theboss17, Jun 12, 8:54am
My trans is slipping.
When i went to drive it after work,i put it in drive then accelerated.but it only revved with no drive.
It had a bit of reverse.
I managed to coax it up to open road speed when it finally gripped,
But it would slip occasionally especiallywhen i went round corners.
Is there any way to fix this!
The trans guy is gonna charge $150 to run some tests. but i dont wont to pay $150 to find out its knackered.
which i suspect it is. i would love some advice please.
p.s the fluid was a bit lower than usual, i added some, but know difference
1990 nissan laurel
diesel
rd28
s34
cheers
mugenb20b, Jun 12, 9:25am
Start off by checking the fluid level, its smell and colour.
next-to-normal, Jun 15, 6:35am
change your oil
40wav, Jun 15, 7:12am
Did you check your oil with the engine running like you're supposed to!
