Subaru Impreza 97 - question
zero77, Aug 9, 1:32am
Who knows where I can find the fuses for the reverse lights! They are a no go and yes I have changed the bulbs. Help would be much appreciated. TIA
mugenb20b, Aug 9, 6:36am
Bottom right hand side of the dashboard. I'll bet that your fuse is OK, and you have a f.ed reverse light switch.
zero77, Aug 9, 9:09am
And how do I or who can fix this f.ed reverse light switch! Yep you were spot on, fuses are all fine :)
mugenb20b, Aug 9, 9:12am
Find the reverse light switch on the gearbox.somewhere, two wires going to it. Unplug the switch and bridge the two terminals on the LOOM. If the reverse lights come on, replace the switch. Easy (if you know where to look).
zero77, Sep 27, 9:18am
Cheers for that, I will get some 'man' help tomorrow to have a look! Thank You
