Dihatsu Sirion High K's Question
angel161, Sep 15, 9:17am
Hi, I am wanting to buy a Sirion and have found a ex rental 2005 with 245,000 kms on its clock, its only $3900. My question is does anyone know how long this will go and if I would get another 100,00 kms out of it !.
msigg, Sep 15, 9:39am
well if the rental cars use them then I would say yes, rental companies can't afford to have maintenance problems with thier cars, so go for the most reliable ones around. make sure you do the corrosion inhibitor in the radiator, Not doing this stuffs most engine in the end.
frank1, Sep 15, 9:45am
Ex rental with 245 clicks and ONLY $3900!--most rental co's get rid of them long before that--not worth that money--anyway would be getting close to the end of it's life-- engine wise.
andy61, Sep 15, 9:52am
245000kms is only just run in for a Toyota motor(Sirions are a rebodied Echo),nothing for the rentals to do 350000kms.Check the gearbox(if a manual) doesnt whine,the Echo had a slightly weak bearing which would need replacement at higher kms.
angel161, Sep 15, 10:44pm
Thanks for your replys everyone :)
