Auto trans problem
chevygirl1, Oct 17, 8:06pm
son was driving home in his 84 mazda famila,when trans stopped working.it wont go into any gears.have watched selector cable and it works fine.help please.
pge, Oct 17, 8:18pm
Look around for a second-hand one.
It sounds like he has blown either the torque-converter, or the primary pump.
Good luck.
franc123, Oct 17, 11:30pm
yep or else the pump drive itself might have failed.Disconnect one of the lines to the cooler in the radiator, run the engine briefly and check for any fluid flow, if there weak or no flow its remove and repair or replace time sorry.
hatchback, Oct 18, 12:08am
Guy Fawkes coming up, torch it and roast marcmellows
goron56, Oct 18, 7:46am
that'll teach him for launching it.
NZTools, Oct 18, 8:19am
Brick it and run a sweepstake on how long it lasts.
fordcrzy, Oct 18, 8:29am
have you checked the oil level!( from memory you pull the speedo cable out to fill it!)
chevygirl1, Jan 3, 1:56pm
yes plenty of oil.looked on TM no other gearboxes on at the moment.so he will have to bike for a while.
