Any idea why auto starts in second?
israeli2, Oct 17, 1:54am
honda accord 1991`2.2 wagon will start in 3rd gear or manually shift it to 2nd and it will pick up speed so you can shift back to 3rd.reverse is ok .
tmenz, Oct 17, 1:57am
Check the fluid level!
There may be a solenoid problem.
timmo1, Oct 17, 2:11am
Does it have a 'snow' button!
Once the car/trans is warm, does it then begin to start in 1st speed!
40wav, Oct 17, 7:17am
Yes, check this. A snow button (a little button somewhere with a snowflake on it) will make the auto take off from a stand still in 2nd to reduce wheel spin.
israeli2, Oct 17, 7:51am
cold or hot its the same.and the green light stays on but goes away as soon as you start moving!
