Ballpark cost for replacement of auto transmission
mrs_murphy, Nov 15, 8:44pm
Got a 2001 ford automatic that likely needs a new transmission. Any idea on a vague cost? Would ring around a few places but they're all closed today and I'm kinda impatient. Just looking for a bottom dollar/top dollar rough idea. Cheers
seadubya, Nov 15, 8:47pm
What model Ford? Focus, Falcon, Mondeo etc.
poppy62, Nov 15, 8:49pm
$100.00 from Pick a Part open 7days. Although they may only have them for purple and yellow Fords.
mrs_murphy, Nov 15, 8:52pm
v6 ford escape
differentthings, Nov 15, 8:54pm
A very rough guess 2.5g-3.5g for a reco
kazbanz, Nov 16, 4:16am
for an escape my guess would be around the 4k mark
intrade, Nov 16, 6:13am
2500 is for my 95 corolla so i am with 4k also and 2,5 is if i bring the gearbox in to there shop still thinking what to do , you want to be sure first it is the actuarl gearbox poster 1 as my one has only mechanicals no electronic often electronic component or wiring are the problem including tsb flash updates to fix some issues on newer automatics
andy61, Nov 16, 9:04am
Ford Escape transmissions are well known for being weak and prone to failing, so will need more a reflash to fix.
franc123, Nov 16, 9:39am
I'd certainly be thinking 4.5k drive in drive out for a rebuild and a bit over half that for a used one but who has told you it needs replacing? They have a number of common faults, some of which can be repaired without removing it, replacement isn't the easiest of jobs on those. Ford and/or Mazda agent or preferably an auto specialist is where the most accurate costings are going to come from given no information about what its doing or not doing has been given. Unless you've cooked it or its split a trans cooler, doing a repair on the one you have might be the preferable option.
monsieurl, Nov 20, 6:24am
Find yourself a 2nd hand one on TM then factor in at least 7 hours labour 2 filters and fluid for 2 changes!
ema1, Nov 20, 10:02am
I'd be looking for a 2nd hand auto box intrade as there is a high chance of finding a good used Toyota auto.
Heck there's plenty of them out there.
mainlander05, Sep 29, 9:32am
My question is,why would he want a Toyota box when he has a ford?
