VZ holden BCM relay needs replacing - anyone know
flagheaven, Sep 21, 3:53am
who does it in Auckland or do I need to take to holden to replace whole setup ?
reason is passengers tail and indicator lights stay on . and good old GOOGLE say its this causing the problem . cheers.
treachug, Sep 21, 4:09am
A good auto sparky should be able to replace it. As long as you can source the relay to solder in. Holden dealer would replace the BCM only - or send it out to get repaired. What part number & level is the BCM. low, mid, lux?
kenw1, Sep 21, 8:08am
Unless the relay contacts have welded themselves, its unlikely to just be the relay, more likely the device that drives the relay, so you may need to try and obtain the schematic diagram.
dolsen, Sep 21, 11:29pm
It is just the relay that needs to be replaced. I wrote a guide on replacing them and posted it to just commodores. Have a read. Shouldn't cost too much to fix.
Don't replace the whole bcm (at huge cost) when it's just the relay that needs replacing.
Also - don't leave it until the heat opens the weld in the light and you then have to glue that up.
flagheaven, May 24, 2:06am
thanks above - especially Daniel. cheers.
