Honda Vtec timing
radar51, Jan 1, 10:06am
1998 honda torneo SOHC. I ve just changed the cam belt at 200000Km.
All the timing marks were lined up etc. All going well. My question is does it require additional timing adjustment or does it adjust itself automatically somehow.
the manual I used was from an earlier model . Cheers.
intrade, Jan 1, 10:33am
lugee, Jan 1, 11:13am
If all the marks lined up and the belt was correctly tensioned, that should be it.
radar51, Jan 1, 9:34pm
Thanks above. I watched that utube clip/.
By the way where do I look on the motor body to see exactly what motor type I have. eg F20B is a dohc
radar51, Jan 1, 9:50pm
Found it. F20B
vtecintegra, Jan 1, 10:02pm
F20B could came in both SOHC and DOHC versions. Should be pretty obvious which one you have just by looking - the DOHC version says it right on the rocker cover
DOHC http://trademe.tmcdn.co.nz/photoserver/full/417285686.jpg SOHC http://trademe.tmcdn.co.nz/photoserver/full/415543631.jpg
radar51, Apr 3, 2:15am
I downloaded (and paid for a workshop manual for an F22B1 motor. Similar but would have prefered the exact model motor.
