DOHC vs VVTi engine in Toyota Wish?
sofieke, Nov 16, 4:29am
Hi everybody, we're looking at buying a Toyota Wish 1800cc, but have noticed there are 2 types of engines around, a DOHC and a VVTi. What is the difference and are they chain driven or cambelt? What would be the better choice or does it not matter too much? Thanks :-)
franc123, Nov 16, 4:50am
There isn't a difference, the engine incorporates both features, it's just that some advertisers don't mention DOHC as virtually all petrol engines made jn the last 20 years and a substantial amount of diesels have it, it stands for Double OverHead Camshafts and Variable Valve Timing Injection, it just describes the valve operation and control in basic terms. Don't let the whole belt vs chain thing sway you too much, again this is part of valve control and there is for and against both systems, it just happens that chain has been back in vogue this century which allows for more compactness and design, reduced cost and less chance of outright failure and no ongoing service requirements, but contrary to popular belief does NOT mean the chain system won't require repair at some stage in the vehicles life. What you are looking at will be chain.
kazbanz, Nov 16, 6:57am
There are only TWO engines and transmissions in the Toyota wish. One is 1800 VVTI (which happens to also be dohc). The other is the 2.0l D4
The 1800VVTi is a darn good engine, Yes it is chain drive
The D4 not so good.
So 1800 is good
2000cc (2.0l) NOT good.
Im sorry to say that some unscrupulous sellers deliberately avoid the D4
sofieke, Oct 11, 6:27pm
Thank you franc123 and kazbanz for your clarifications, very helpful :-)
