Gearbox swap 4m40 (LWB) to 4d56 (SWB) 94 5 sp man
remus2, Mar 21, 8:22am
This is for a Pajero. Is this possible (bolt on)? and without to have problems because different gear ratio to back diff? trans axle nr slightly different- one 3 (at4m40) instead of T (at 4d56). I am a bit concerned to spend time and money before I get some good advice in this issue. thank you.
mrfxit, Mar 21, 8:54pm
Ring & email around the wreckers asking them the same question.
Also try the gearbox reco places
robbos1, Mar 22, 9:25am
Not compatible. Different bellhousing, starter, and mountings. just for a start.
ozz1, Mar 23, 12:11am
diff ratios wont be a problem. BUT as robbos1 said. it wont fit. completely different gearbox.
remus2, Mar 23, 10:41am
thank you, big help. I was very close to pay 550 for that.
remus2, Mar 23, 10:47am
if any swb pajero sitting in back yard with a 4d56 engine I am keen to pay 500-550 depend of location for the gear box. thanx
frank1, Mar 24, 3:42am
Whats the prob with your g/box?--noisy?
remus2, Apr 13, 10:45am
gear box is good, no problem but it is difficult to find a transfer case by itself. transfer case was run without any oil for ? long and it is full of broken bearings.
