96 polo struts
tatts2, Jan 18, 3:29pm
Are the front struts spose to have slight play. Has always had play & passed wof np its no worst than other passed wofs. Now the garage has failed it.
intrade, Jan 18, 4:46pm
No play. it affects drivability it should handle like on rails
gtrmotorsport, Jan 18, 6:00pm
Yes, they are designed to have slight movement when unloaded. But the rubber bush is probably a bit worn by now and will likely be requiring replacement.
llortmt, Jan 18, 7:19pm
What? There's heaps of fwd cars on which it's permissible to have some play in the front top strut mounts. Honda Jazz/Fit, Holden Astra or VW Polo to name but a few.
andrewph, Aug 5, 9:14am
Upper strut mounts, would be my guess. the golfs are really bad for it. As they get old they compress and when the wheels are hanging freeyou will get movement because there is clearance between the mount and the cup shaped piece they fit into. When you get it done get the mechanic to show you the old mount compared to a new one. There will be a big difference in height. poor design.
