Where can I buy decent bullet connectors!
leighfrancesca, Sep 13, 4:01pm
I like to use them for car audio wiring now and again.The only problem is that I've tried Repco, Supercheap and Dick Smith and the quality of their connectors is crapola.The insulation lugs are some sort of cheap plastic that seems to fall apart and I will quite often bend the metal terminals in half while trying to connect the male and female parts.
Does anyone know where I can find decent bullet connectors!
zoltec45, Sep 13, 4:21pm
bjdw, Sep 13, 4:23pm
I've sold many thousands of the Narva brand connectors to proffesionals and amatuers and I have never had a packet come back with a complaint about quality.I may not have a lot of practical experience with using them but surely if there was anything wrong with them I would have heard about it by now.
dansue, Sep 13, 4:35pm
Narva and a proper set of crimp pliers.
Cant go wrong.
attitudedesignz, Sep 13, 4:37pm
Are you useing decent ratchet crimpers or the cheap ass plier type!
I've found even the crappiest terminals work ok when useing a good ratchet type.
http://tinyurl.com/3wd7uou
bigfatmat1, Sep 13, 6:04pm
use narva ones hella and all others suck hairy balls with their cheap plastic that breaks
xraps, Sep 13, 6:27pm
http://www.utilux.com.au/
With the proper crimp tool and a basic assortment these are (imho) the best.
leighfrancesca, Oct 25, 5:51am
Thanks for the replies guys, much appreciated.
I think I was probably a bit spoilt for choice when I had access to aircraft grade connectors (not that they use bullet connectors on aircraft).
Yes I use a proper(ish) crimp tool, not the plier type.
