VP Calais imobilizer remote, where to new one!
hatchback, Sep 13, 4:43am
Just bought a VP Calais but the door lock/ imobilizer remote is abit stuffed and you have to press it alot to finally get it to work.I wouldnt bother using it at all but the car self imobilizes after a few minutes when you turn off the ignition, any thoughts!
scotty20001, Sep 13, 5:06am
mr minut will do it for around $120 just bring them the original key.
treachug, Sep 13, 5:17am
It all depends on if its a series I or II Calais. Series I have the hard buttons & black case with Holden on the back ot it & not BCM controlled whereas Series II has the soft buttons & black case with Holden on the front face & is controlled via BCM. If series I car, open remote up, there will (should) be a white label on the printed circuit board with code eg: 603884A. You can get a genuine Mongoose remote via local Holden dealer or if they have no idea let me know via my auctions & I can supply. Series II remotes are only available via Holden dealer & have to be purchased as a pair & both recoded to the BCM via tech1. You cannot recode a new single series II remote to the BCM
hatchback, Sep 13, 8:31am
Thanks for all that info, it apears to be a series 2 remote, I will check with Holden, Cheers
dave653, Sep 15, 8:29am
I got our new VN Calais remote from Mongoose, $105 incl post. Holden couldn't help.
treachug, Sep 15, 7:00pm
I worked in Holden parts for years - we dealt with Mongoose regularly - so your case was more like the Holden dealer you tried had no idea where to get the remote from.lol
icemans1, Oct 29, 1:58pm
i think it's about a hundy if ya with the AA
