Im looking in to buying a torque wrench with angle functions. There arnt alot out there and was wondering if any one has had anything to do with any brands of these and there thoughts. Thanks Guys
supernova2,
Sep 16, 5:59pm
White pen, couple of dots job done without any expensive tool.
irule,
Sep 16, 8:55pm
What do you mean by angle functions! If you mean a ratcheting one norbar and snapon both make them and both quite good.
I have used a snap on model -1/2" drive, yeah it saved pissing around with an angle gauge , pretty handy I would readily use one if available but I wouldn't spend the $1000 for the one I used. In my opinion its something that has always been supplied by the workshops I've worked in. Also regardless of what tool I am using to tighten the bolts/nuts when torqueing a head or similar I mark them for reference anyway. That 3/8 model shown looks too small for torqueing diesel heads comfortably
I hate those bloody things. They can sometimes stop moving while you're tightening the bolt, and by then you have no idea how many degrees you moved.
