Carby back firing
missmaverick1, Sep 21, 10:22am
got a Lada Niva and it has started back firing out the carby what would be causing that! i have recently been working on it might i have reconnected a hose or something round the wrong way! it doesn't appear so but i might have missed something.
crzyhrse, Sep 21, 10:29am
Go through what you did with a fine toothed comb to make sure it's as it should be.
When does it backfire through the carb! Have you verified the cam timing!
gadgit3, Sep 21, 10:29am
Back firing out the carb is a timing issue or very lean burn issue
mariska67, Sep 21, 2:51pm
fouled plugs , common cause of this problem.
ginga4lyfe, Sep 21, 4:13pm
incorrect, it wouldn't cause that, only would cause poor running or missing, and higher fuel consumption, but timing and a very lean mixture will cause that
ginga4lyfe, Sep 21, 4:16pm
have you by chance placed the plug leads on the wrong way! The firing order is 1324 if you swap plugs 2 and 3 so that it was 1234 it would cause backfiring through the carb
missmaverick1, Sep 21, 5:20pm
Thank you all. I will try those options.
mariska67, Sep 21, 6:17pm
i beg to differ Ginga , personal experience tells me you are wrong. I had fouled up plugs which caused backfiring thru carb when engine came under load. Cleaned plugs and bingo! no more backfiring.Do your homework before saying im wrong.
ceebee2, Sep 22, 6:54am
As above.go through EVERYTHING you have done and double check. Too hard to assess over the net. I have have dozens of customers come in with a problem only to find out 2 hours later they had done something quite unrelated to their description!
bellky, Sep 22, 7:48am
^^ this.
ginga4lyfe, Sep 22, 10:21am
Do my homework! No thanks, my experience also speaks for Itself.
missmaverick1, Sep 23, 10:24am
it was the leads around the wrong way.
bellky, Sep 23, 10:28am
in other words - timing.
motorway, Sep 23, 10:50am
You're all wrong.
candy1213, Nov 11, 5:40pm
its a ladaits telling you something , bang bang take me to the car grave yard
