Borgwarner 25 spline,
402rat, Oct 3, 1:14pm
hi ive just put a lsd diff head into my vl,before removing the lsd from another car i rotated a wheel forward and the other was going in the same direction but only one rotation, then it would only spinforward very little each time,so then i removed the diff hat to removed dirty oil,i then broght the diff head for my vl but its in and its not working how it should, also has new lsd oil .should i take to shop!
mellisa2000, Dec 6, 11:46pm
Tired replacement diff. Replacement oil is a start. Then, you couldtry to load the diff up, left foot brake, foot on loud pedal, as though you were trying to do a skid, but not to that point. This can help tighten up the diff. I'd say it's the clutch plates slipping due to wear, abuse or wrong oil though. good luck with it.
Fish.
