hi there ive just drained tha diff on quad its a 1996 kawasaki KLF 300 must of needed it as oil was almost as thin as water and vry dirty looking. anyone kw wot grade oil i replace it with! motor oil, trans oil, gearbox oil! Im guessing any oil is better than none! lol
jummybuffett,
Oct 5, 9:07am
something is better than nothing,just use the oil from the toyota
bill-robinson,
Oct 5, 9:32am
you could phone Kawasaki and get the right info.I know time and money.but the probably have a 0800 number.
desmodave,
Oct 5, 12:10pm
Google is your friend to. Service Infromation Valve Clearance Cold - Inlet : 0.10 - 0.15 mm Valve Clearance Cold - Exhaust : 0.15 - 0.20 mm Final Drive grade : SAE 90 Final Drive quantity : 300 cc 1991 onwards 350 cc Engine Oil Grade SAE : 10w/30 Engine Oil Classification API : sg Engine Oil quantity with filter (litres) : 1.7 Idle Speed (rpm) : 1300 - 1400
kngfhrt,
Oct 7, 7:13am
wow thanks 4 tha info guys! i only kw hw 2 get around on trademe i must venture out and try and google things!
skin1235,
Dec 14, 9:48am
whatever you do, do NOT go up the top where it says http:\\trademe etc, and scrub out the trademe and all others behind that and replace with google.co.nz I repeat - DO NOT do this
if you do you will be saying goodbye to your life and family every time you do a search it will return something like 3million hits, popular searches will return 10million hits, you will never leave the computer
a search for 'how much oil in a kawasaki 300 diff' will frighten you with 3.25 milliom returns - thats 3.25 million opinions, some the same, some different. - your personal life is over, lol
