I need to tap into the horn wire. from what i can see, the horn wire is on the same plug as the airbag (wrapped in yellow tape, yellow plug). of the 4 wires going into the plug, 2 are yellow and 2 are green. would I be correct in assuming the 2 green are for the horn! i dont fancy setting the airbag off
ringo2,
Oct 11, 11:57am
Assumption is the mother of disaster.
jsbike,
Oct 11, 12:01pm
which is why im here.
steve312,
Oct 11, 12:11pm
Here we go again.What vehicle!
Normally the horn will not be on the same plug as the airbag.The yellow plugs etc are the air bag circuitry.Mess with that stuff at your peril:o)
bitsy_boffin,
Oct 11, 12:17pm
Why do you need to tap into it there.I assume you are fitting a new horn, air-horns or something, so just take it from the back of or at least closer to the existing horn.
carmedic,
Oct 11, 12:20pm
NOOOOOOOOOOOOOOOOOOOOOOOOOOOOO- OOOOO!
tmenz,
Oct 11, 1:50pm
There should bea horn relay somewhere - find that and tap off from there!
saxman99,
Oct 11, 2:25pm
C'mon guys, what could possibly go wrong.go wrong.go wrong.go wrong.
the-lada-dude,
Dec 27, 4:47am
reminds me of the roadrunner cartoon.BeepBeep .KARBOOMM
