Mini stud pattern
fryan1962, Oct 22, 7:18am
what other car has same stud pattern it is for trailer so could be bigger rim size
old mini pattern as well just need to get a set of rims and tyres
franc123, Oct 22, 7:45am
a better idea is to change your axle and fit a common Jap or Aussie stud pattern hub instead,those old Mini hubs on trailers are a damn nuisance, especially if its a boat trailer, not only because of the pattern but the cost of the hub bearings too.
fryan1962, Oct 22, 8:21am
It is on a shredder from the 40s and the stubs look from 20s it is not going on the road only the section so would like to keep orig
fryan1962, Oct 22, 8:23am
I just went through drama with boat trailer outer bearings $30 each.and could have got axle new stubs and bearings $65.then bearings $15 ever time after that
toyboy3, Oct 22, 9:44am
try austin A30 a35 =13" and Morris minor =14''
mrfxit, Oct 22, 12:14pm
socram, Jan 13, 6:50pm
Vauxhall Viva and possibly Hillman Imp may have the same size as does Mini Metro - I think.
