B1600
kamocivic, Oct 22, 1:27pm
makes clicking noise when turn key but wont start has
new battery.
bevharris1938, Oct 22, 1:28pm
Starter Motor ! Battery terminals !
kamocivic, Oct 22, 1:41pm
ive had 4 1 week and its prob started twice what you mean by battery terminals!
bevharris1938, Oct 22, 1:45pm
check the battery terminals for white power / corrosion , if there is shit loads of corrosion on the battery terminal that might be the problem. Pour boiling water over the battery terminals id they have that crap on them. Check they are TIGHT aswell
kamocivic, Oct 22, 1:55pm
tight and clean still nothing.ive jump started couple times
bevharris1938, Oct 22, 1:57pm
Could be the starter motor solenoid not engaging properly, hit it with a hammer or stick then turn key
bevharris1938, Oct 22, 2:01pm
Also check your battery has the right amount of charge , should be 12v sitting as is , and about 13.5 volt with the car running.
bellky, Oct 22, 2:02pm
this^^ also you can put it in gear and rock the car to accomplish the same.
crzyhrse, Oct 22, 2:04pm
What makes you think that!
bellky, Oct 22, 2:05pm
what are talking about! have you ever done it! i suggest you try it some time
kamocivic, Oct 22, 2:08pm
battery charge at 12 and not sure about solanoid thing.and rocking the ute didnt do nething tried other day
bevharris1938, Oct 22, 2:10pm
Check the battery voltage with the car running , should be reading about 13.5volt
bellky, Oct 22, 2:11pm
theoretically rocking the ute would have shifted the solanoid enough to engage it so probly not that. sounds like no grunt in the battery to me, or starter stuffed. i don't know
bevharris1938, Oct 22, 2:15pm
If the battery is not running at 13.5v with car running your problem will be the battery not getting enough charge , alternator problem
kamocivic, Oct 22, 2:16pm
dad said same thing about solanoid and year will buy nother starter motor or battery and c what happens
kamocivic, Oct 22, 2:17pm
i even tried jump starting with other car and just nothing at all
bevharris1938, Oct 22, 2:20pm
Push start it and check battery voltage running
bellky, Oct 22, 2:22pm
can't be battery then - must be connections or starter motor (or solanoid)
you need good earths from the bat to the body and from bat to engine/starter ay.
thunderbolt, Oct 22, 2:23pm
The hammer tap might free up a stuck brush.
Rocking the car will do nothing unless the solenoid is stuck engaged due to low voltage.
bevharris1938, Jan 13, 1:53am
good advise , wont be battery if you tried to jump it and nothing
