SR20 noisy tappets!
dasfi, Oct 28, 7:00pm
Been told by a couple of people to take tapiit cover off, remove oil line rail things and drill the holes out slightly bigger to 0.5mm! as they have really small holes in then, allot better flow apparently, Anybody heard of this! Cheers
philltauranga, Oct 28, 7:10pm
I was advised NOT to do this as it alters the oil pressure, insted use a gas axe tip cleaner to clean the holes and a good degreaser and compressed air to flush the crap out of them.
dasfi, Oct 28, 7:13pm
Sweet as, cheers, yeas i also thought about the oil pressure so havnt done it yet, its not that bad, only a little in the mornings, but yes will try that idea thanks guys
johnf_456, Oct 28, 7:16pm
Make sure you use the right grade oil also, sr engines hate to be neglected. So lack of oil changes and the wrong grade oil can have its affect.
dasfi, Oct 28, 7:16pm
whats the correct grade oil! 10w 40! and an engine flush!
NZTools, Oct 28, 7:17pm
Cleaning the oil holes will save your cam lobes, but it wont make your hydraulic lifters any quieter. A shot of Pro-Ma MBL8 with your nice new clean oil will help the tapping.
dasfi, Oct 28, 7:17pm
Its a 97 by the way
philltauranga, Oct 28, 7:20pm
Go to Nissan and get the torque sequence and torque rate for the bolts that hold the oil rail down as they also hold the cam caps down when you come to reassemble it, and cover the lobes in start up lube or oil before you put rocker cover back on.
jono2912, Oct 28, 10:16pm
In the SR20DE, I use Magnatec 10-40 to get rid of the start-up rattle.
Works a charm.
r15, Oct 28, 10:35pm
Valvoline 10-30 works real nice in these. quiet as.cant remember the product name itself though
jono2912, Oct 28, 10:58pm
Doesn't get rid of the start-up noise tho :/
zephyrheaven, Oct 29, 7:03am
By 97 it probably wont have the feed tube style - oil change with some Mazda Genuine oil & a shot of Pro-Ma as NZT has stated will suffice
dent, Oct 29, 9:01am
quite correct zephyr. Is the start up noise a rattle. If so its the chain tensioner taking its time to pump out.
_peas, Oct 29, 9:16am
Mazda oil!Is that a typo or does Mazda make some really good oils!
I have a friend who is a mechanic (has been for many years) and he recommended drilling out the oil feed line on SR20's. He did this to his own car and a few race cars that he has helped people build.Never seemed to stop his Primera getting along alright.I don't recall the size that he said to bore them out to however which may (will definitely!) make a difference.
hopie, Oct 29, 10:13am
SR20s are known for this issue. take them out and blow them with a air compressor as little bits of crap get stuck in the holes.
dent, Oct 29, 10:23am
Ive drilled a few out to 1mm dosnt affect the oil pressure to any major amount.
vivac, Oct 29, 2:02pm
Its more likely to be the VCT rattle that SRs develop, its not harmful just annoying and expensive to fix.
fordcrzy, Oct 29, 4:09pm
hydro tappets get pretty gunked up.heres a good mazda HLA guide to cleaning them.check out how crappy the trapped oil is.
http://www.miata.net/garage/hla/cleaning.html
dasfi, Oct 29, 5:18pm
Sweet as cheers guys have a few ideas now, nothing major im just fussy, ill have a look over next week or so
zephyrheaven, Nov 3, 5:14am
Yes Mazda make a lovely thin oil with loads of additives & detergents - Ive used it in Mitzi's for noisy lifters & works wonders on Nissan SR motors
ginga4lyfe, Nov 3, 9:07am
I wish i knew that before i serviced my friends Legnum VR4 with noisey lifters.
gtfowar, Jan 26, 9:10am
just go buy new ones from nissan haha. They stock them for abour $200 I think. and always run a 10w30 or 40 in these or they just block the fine oiling tubes
