HELP how can i get a 10 disc
coolcharmgirl1, Aug 10, 11:54am
out of my cd player one disc must be stuck and just comes up with MD error now,in its in the boot any suggestions.
elect70, Aug 10, 12:00pm
I had to take mine apart to get stuck disc out
srrolla76, Aug 10, 1:06pm
u will need to take the cover off the stacker to get it out. its quite common for these to jam. i have taken many of them out for customers as they get sick of it happening. but take the cover off. should be 3 or 4 screws on either side of the stacker.
andrea_w, Aug 10, 2:35pm
There is a trick that works on around 50% of stackers. slide something down the long sides of the magazine (one side at a time is ok), don't move it side to side. push it down, pull it up, move it across, push it down etc. There is a catch down there on some stackers, if your stacker has one and you hit it, the magazine will pop up. This is assuming there isn't a CD jammed half way between the magazine and the stacker itself.
I always used a paint scraper (as in the pic below) for this job
http://www.sitesplus.co.uk/user_docs/638/Image/50mm%20Paint%20Scraper%20edited.jpg
andrea_w, Aug 10, 4:53pm
I'd say that has a much higher success rate than my method. it makes the dated piece of technology that is a stacker go away. permanently.
coolcharmgirl1, Nov 15, 9:48am
Well after a year i have finally got the stacker out,there was a cd stuck half way in between so i managed to push it back in before taking stacker out ,i had 2 cds in one stupid me.Now i still cant the cd to work comes up still saying md error dose anyone have any suggestions please
studio1, Mar 3, 1:48pm
If you had two discs in one slot and the whole thing got jammed up, chances are it's screwed the mechanism - hence the error message.
Interesting that it says MD error, not CD error. MD is Mini-disc.
