checked all fuses and relays tryed another horn and still nothing any ides cheers holden vt 1997
pico42,
Nov 15, 6:56pm
Connect horn direct to battery!
pollymay,
Nov 15, 6:57pm
maybe check the relay is being activated then go from there. My horn contact on the steering wheel wore out on mine and needed to blob solder on it
andrew194,
Nov 15, 7:03pm
thanks i tryed direct to horn and it works will i get hit in the head with the airbag if i take the cover off lol
woki,
Nov 15, 9:08pm
Disconnect your battery before attempting to remove the cover . Airbags can go off!
pup2,
Nov 16, 11:05am
Air bag and horn on the wheel.poss clockspring has a broken wire
sifty,
Nov 16, 11:08am
shout BEEEP when tester presses horn button.
a.woodrow,
Nov 16, 11:15am
hmm if the clockspring is broken the airbag light will be on.
pup2,
Nov 16, 11:35am
Nope. Ribbon wire in a clockspring. can have 3,4 or more different circuits. Depending on what you have on the wheel. ie Cruise control, stereo controls, horn and airbag. I haven't come across any clocksprings using CAN yet. Air bag circuit is always separate to everything else. Pull one apart when you get a chance and you can see why they break. Thin wire on ribbon.
a.woodrow,
Nov 16, 12:56pm
Ahh true I suppose, wasn't thinking the answer right through. Ive had a few apart, they are a bit of a rubbish design, replaced countless numbers on latest toyota hilux
bellky,
Nov 16, 12:58pm
some of the older fellas use viagra
sifty,
Nov 16, 1:02pm
it's just cos their missus is old and fugly. I reckon any old bloke who 'can't get it up' would have a horn like a rhino if a hot 22 yr old was on the cards.
pup2,
Nov 16, 1:31pm
yea, done a few hilux's as well. Some of these new cars are going to be a real nightmare in a couple of years. $30 G for a new computer on the new ford rangers at the moment and stuffing up a jump start on them will kill it.Bugger
spead,
Nov 16, 1:39pm
service station
urbanrefugee54,
Nov 16, 7:02pm
90% of service stations are only there to sell fuel & lollies. ooh & pies.
ryans,
Nov 16, 7:19pm
Some cars need the battery disconnected for hours before it is safe to work with air bags.
fordcrzy,
Mar 8, 10:56pm
just get one of those bumper stickers.
"CAUTION horn broken, watch or finger"
