hi, have a '96 lc4 motor, I know i need the magneto/stator, capacitor, and coil wired up, but do i also need the rectifier! I'm not running any lights anymore, just want spark. also, what is the wire coming off the terminal on the side of the head, and is it neccessary! cheers
rallybaz,
Nov 10, 5:49pm
after more research I've realised I don't need the regulator if i'm not running lights, back to the shed!
rallybaz,
Nov 16, 4:33am
Still stuck, can not figure out if i need to use all 6 wires coming from the stator, and none of these are displaying any voltage when being kicked over.
lyn9,
Mar 6, 9:49pm
if its the same as the last bike i did it was, 1 or 2 wires out of magneto for lights, and 3 or 4 went to the cdi. i wire out of cdi to kill switch, 1 wire out of cdi to the coil. if this is any help. the lighting wires had voltage when i used to kick mine over but wasnt connected to anything
