Coil packs - rb20det
andrea_w, Nov 16, 2:11pm
Yes - with an exception. They must be R32 coil packs (auction doesn't specify). R34 RB20 coil packs will not fit.
jsbike, Nov 17, 6:28am
depends on what car the rb20 was orig in, the plug is diff between models (eg rb20 from r32 or cefiro) Some plugs are like this (---), and the other like this (III). as long as the pins are facing the same direction as your old coils, they will work.
dj.indica., Nov 17, 7:01am
check the numbers . MCP-1330 are the turbo ones
