EDELBROCK 500 CFM CARB TUNING
floscey, Nov 21, 7:43am
doesnt anyone know of a tuning shop that knows all about Edelbrock carbs !seems everyone knows how to tune Holleys .Can anyone recommend somewhere.
sifty, Nov 21, 9:50am
should be ample stuff on the interweb if you want to have a go yourself.! usually step by step processes available on utube etc, and bound to be message boards offering advice.
mariska67, Nov 21, 2:06pm
CSL at 3071773 , did mine real good.
typhoon666, Nov 21, 4:02pm
Rodger Bertram 2765688
darryl, Nov 22, 11:24am
I had the same issue in Gisborne. Got a car with an Edelbrock on it - no mechanic here wanted to touch it. So I put a Holley on and sold the Edelbrock
brettley, Nov 22, 2:33pm
Weber Specs he is a carb guru. in silverdale i think now
pdc1, Nov 22, 2:39pm
Try and stick to the edelbrock, even if it means having to learn all about them and doing it yourself. For street use they are a much better carb than that one that starts with the letter H .
floscey, Nov 22, 7:56pm
I had a go myself at trying to get tune sort of ok , but its on a six cylinder soguess i need to jet it down alot more.Always running rich , my be over carbed ! . Goes sweet at top end ,4 barrells open. Just loves that BP 98 @ 2.22LITRE.
manda00, Nov 23, 11:01am
If you go to edelbrock.com/tech you can download tuning info videos etc about your carb also a few on u tube.These are excellent carbs, threw my holley away and have never looked back.
cuda.340, Apr 2, 8:42am
best thing about them edelbrocks is that theres no gaskets below the fuel line. they're a very good street carb & are easy to tune but if you don't know what to do then find someone who does. out of the box they'll run on almost anything & it may just need a fine tune on the mixture screws. other than that they might need a downsize on the main jet. the stepped needles will keep the fuel mix spot on as long as you have good vaccuum. if you want a hungry gas hogg carb to go real fast, the Edelbrock is not your best choice.
