Strange reason to fail a WOF. apparently they are too yellow. any tips on how to clear them up! Seems a silly reason to go to the wreckers and get a whole pair, which will come at great cost, hardly worth it for a cheap runner.
rovercitroen,
Nov 24, 4:12pm
Apparently there is a guy in Auckland who recolours them. I don't know more than that though sorry.
tradingfreak360,
Nov 24, 4:15pm
Autosol and some elbow grease should clear them up
rob_man,
Nov 24, 4:20pm
Call into your local panel & paint shop and get them to run the buff over them, ten minutes tops.
marcos1,
Nov 24, 4:23pm
Turtle wax have a kit to reco headlamp lenses. I tried it out a couple of weeks ago and it worked ok.
skin1235,
Nov 24, 4:24pm
check posts 14 and 15
a.woodrow,
Nov 24, 4:29pm
Any cutting polish rubbed on with a rag will do, and a light buff afterward with a clean rag. They fail because of reduced light output.
richynuts,
Nov 24, 4:33pm
Brasso and meths will have them like new again.
unbeatabull,
Nov 24, 4:34pm
Glass or plastic!
Glass, a good glass cleaner/cut polish and buff will do the trick
Plastic, if you get some fine wet n dry and sand then cut polish, sand cut polish etc it will do the job too.
curlcrown,
Nov 24, 4:42pm
I can fix that in less than a minnte.
afer_daily,
Nov 24, 4:53pm
is that a nek minnte
poppajn,
Nov 24, 4:56pm
I just used Jiff on mine, worked good
a.woodrow,
Nov 24, 5:00pm
Have you ever seen glass headlights turn yellow!!
unbeatabull,
Nov 24, 5:23pm
Yes. Early Falcons. We get quite a few each year.
girlracer2005,
Nov 24, 5:35pm
repo paint doctor i always use it
alimac1,
Nov 24, 6:12pm
Meguiars Plastx
crzyhrse,
Nov 24, 6:25pm
2000 grit wet then Autosol.
fordcrzy,
Nov 24, 6:48pm
2000 grit then megiurs "fine cut cleaner"
friendly_prawn,
Nov 24, 6:50pm
done mine by using a rag, a little toothpaste and a 2 minute scrub. clean as, and got my wof. Really, thats all it takes.
cypherboy,
Nov 24, 6:54pm
2000! That will be as abrasive as a wet piece of newspaper. I use 1200 wet and then a quick buff with some 3M light polish, just like new.
fordcrzy,
Nov 24, 7:00pm
i guess it depends on how bad it is.ive used both 1200 and 2000
twinroses,
Nov 24, 7:27pm
Drop into 518 wairakei road 8-4 sat 9-3 sun ill sort it 4 nothing cheers jb.
crzyhrse,
Nov 24, 7:46pm
Yep, 2000. Maybe I'm just more particular. It takes a couple of minutes a side.
