Can someone please answer headunit questions!
nutslap, Nov 24, 6:29pm
When a head unit says it has ipod control does that mean you can control songs etc via headunit or do you have to use the ipod for that!And what does the Voltage on the RCA outputs do!IE difference between 5v and 2.5v!Cheers
vtecintegra, Nov 24, 6:32pm
The first generally means the iPod can be controlled via the stereo - no need to touch the iPod itself
I think higher voltage preouts mean you need less gain on the amp, so less noise
nutslap, Apr 6, 9:43pm
Mint,thanks for that explanation!
