On the power steering pump, I've loosen off the bolts on the adjustment part with the slide bracket, but it still won't move. Do I need to loosen off the big bolt that it swivels on too!It is very difficult to get at (for and amatuer anyway).Thanks.
mike844,
Jan 20, 3:31pm
don't forget getting a new water pump mine broke just after changing the belts ended up breaking the gasket also get the belts adjusted when they wear in
tmenz,
Jan 20, 3:43pm
What make and model! Probably yes!
bjdw,
Jan 20, 4:34pm
Got it. Didn't even lose to much skin.
Jan 11, 5:48pm
Um you would be one pretty muscly fulla if ya can move it without loosening thae bolt
