Should be easy as, just nuts and bolts and a couple of spanners.do it yourself job.
Nov 29, 6:30pm
Yep, DIY job, but please use new high tensile nuts and bolts (grade 8.8) and make sure they are FT.
dave653,
Nov 30, 8:15am
That looks like a light wieght towbar, Don't go dragging 1/3 of a cube of builders mix with it! I've seen 3 bars that failed, two on commercial vehicles, all made by. the towteam!
crzyhrse,
Nov 30, 9:06am
That's a pretty crappy bar. Those side plates aren't braced to the cross member and they seem to have stress raising sharp corners.
clairen,
Nov 30, 9:42am
Thanks guys, glad you mentioned that it looks pretty light weight and crappy.We have decided just to get it all done at the Tow Bar place.
mike77,
Nov 30, 9:59am
Ditto, wouldn't buy a tow bar unless it's rated and from a reputablesupplier. Buy easy as to do it yourself.
rover79,
Nov 30, 10:08am
At 150, find out if it complies, take a pic to who does your warrants. They may beable to tell by looking otherwise make some arrangements with seller that you will pay after you show your mechanic. The guy says was custom made in 2010 for a company vehicle so it should comply, then again might be why its getting sold, might of been made, tried to get a warrant and couldn't get one with it on. ASK
crzyhrse,
Nov 30, 1:04pm
There is no specific compliance for towbars used on this class of vehicle other than "fitness for purpose" and that is purely subjective.
sr2,
Nov 30, 2:33pm
Although more than adequate for bolting on a tow bar 8.8 is structural grade not high tensile.
mike77,
Nov 30, 9:59am
And that one looks like it's already bent!
