Rb25det not boosting or idleing
limit11, Jan 24, 7:44am
have a s1 25det which has never run properly since ive had it ive changed. afm ,ecu ,o2 sensor, tps ,had the ecu scaned was ok,checked for vacum leakes and stil isnt running properly any ideas thanks
jsbike, Jan 24, 8:00am
checked for fault codes!
limit11, Jan 24, 8:06am
yea got the ecu scaned for fault codes
ct9a, Jan 24, 8:22am
sounds like if you just changed the three things
it would be a faulty AFM
jsbike, Jan 24, 9:10am
cam angle sensor!
limit11, Jan 24, 11:23am
x1
i just bought the afm from a wrecker should be ok how can i test it
and how can u test the cas!
jsbike, Jan 24, 11:40am
swap it for another, usually though they either work or they dont rather than causing bad running
limit11, Jan 24, 12:09pm
yea cas should be ok its like a bog/miss when boost comes on but if u eze throtle on it goes a bit better jus changed plugs and gapd them still no diff!
limit11, Jan 24, 1:16pm
is there any tests u can do to check afm!
mechnificent, Jan 24, 2:59pm
Sounds like either boost cut or knock problems. is the motor itself mechanicaly sound! Got good vacumm! No bad noises!
How modified is it!.
escortmadman, Jan 24, 4:26pm
have you canged the coil packs! sometimes they pack up
1fordluva, Jan 24, 5:01pm
Get someone to stay in car while it is running or to keep it running at low revs,then spay throttle body cleaner around all the vaccum hoses and manifold,you will find your fault.
Waste gate jammed,or ecu rooted.
rayzor14, Jan 24, 7:11pm
Also check all intercooler hoses for leaks.a leak there will cause similar issues.
Thats the ones under the bonnet and (assuming it still has factory cooler) the ones in the left behind the front bumper.
jsbike, Jan 24, 7:42pm
venting the cam covers to atmosphere!
gtrmotorsport, Jan 25, 4:56am
unplug the afm it should go into a "limp home mode" if it runs better then it is the problem , have come across this many times the client has fitted a salvaged afm and the vehcle still did not run right so i unplugged it and it ran better as the salvaged unit was also stuffed.
limit11, Jan 25, 7:07am
engine is sweet as far as i know iv pressure tested al the fmic piping and vacum lines no leaks. iv changed factory wastegate actuator,its got wasted spark so should be sweet,iv got it to idle 4 about 20 sec then dies i think it may be faulty afm wil try unpluging
1fordluva, Feb 1, 1:16pm
See if you can switch out the ecu with another,I know a person that had this problem with a nissan only a few days ago.
First it showed knock,then afm,used mine a good one but still the same.
Switched the ecu and away it went.
