I just bought a second hand car. it has a good head unit, but only one crappy speaker on the right side.
I want to have a decent sound (preferably 4 speakers) but don't want to spend more than $200
I'm assuming amp & sub is out of the question.
Can I get a good speaker sound setup for around/under $200! (already got head unit) Would a simple 4 speaker system suffice! and what are the cheapies like (warehouse brands etc) or do I really need an amp & sub get a quality sound!
cheers
cuda.340,
Jan 30, 6:23pm
buy 2 sets of Sony component speakers. it's as good a Bass you'll get without forking out for a Sub & Amp.
tuttyclan,
Jan 30, 7:58pm
Home stereo speakers work well
richms,
Jan 30, 8:19pm
Yup, some off a crap mini system up on the parcel shelf. Dont get a matching pair as that will ruin it.
Also dont worry that they will smack you in the back of the head if you stop quickly, thats just a minor thing.
In general, a half decent set of components cost about $160 not leaving much for rear speakers. I would get a good pair of the largest speakers that will fit in the front (5"/5.5"/6") and a good pair of 6x9's for the rear. I would also leave about $30ish spare for some large speaker cable from Jaycar as the standard OEM speaker wiring in most cars is absolute rubbish.
mr_lovebug,
Jan 30, 9:40pm
I have told a mate to fit 6" 3ways in the front & 6" 2ways inthe rear of his car.Sounds good & was cheap.
He got the speakers from supercheap auto.
If you can get some components they will give a much nicer sound,have those in the front & use a pair 6x9s in the rear. No need to amp them.
Personally i have a pair of 4" in the front of my car & 6x9s in the rear. Thats ALL my car can fit.
carkitter,
Jan 30, 9:44pm
Not too bad. 4 way is impressive, but paper cones for mid-range! Hmmm. Also 102mm deep is quite a lot. I hope the OP has plenty of room free to fit those.
mr_lovebug,
Jan 30, 9:47pm
Thats common with 6x9s.
Also they are best suited for rear parcel trays with spacers etc.
carkitter,
Jan 30, 9:53pm
My car has 4" in the bottom of the dash, I may be able to squeeze 5" in there but my plan is to make a custom enclosure for a 6" speaker in the bottom of the doors. It'll mean reshaping the door pockets and might require some parts from a wrecker but the final result will be worth it. I want it to look as OEM as possible.
jono2912,
Jan 30, 9:56pm
Hey, what car you have! May have a template for you.
next1eve11,
Feb 20, 2:09pm
6" front speakers or whatever fits, and two 6 x 9z, kenwood, sony, pioneer etc. Then a lil later on can add a sub n amp, quite a bit of 12" pioneers going cheap on here, cheap but good set up.
