Elec Fan for Vg valiant
jason18, Jan 31, 7:18pm
Have the old 245 and wanting to get an elec fan setup on the radiator so I can get rid of the belt driven one. What you guys recommend and how about the size! Its the original radiator in there. It going to be painted within the next two weeks depending on weather so gotta finish it off so I can go cruising. http://tinyurl.com/6z22nja Any of these any good!
roys351, Jan 31, 7:23pm
i used 2 elec fans out a toyota and had a thermo switch fitted into my bedford radiator running 4.1 falcon mtr works well
jason18, Jan 31, 7:45pm
One front & one on the back!
johnf_456, Jan 31, 7:50pm
Budget!
jason18, Jan 31, 7:51pm
I dont want to spend a fortune but no point scimping on the cooling system I guess.
roys351, Jan 31, 7:52pm
both running at the back to draw air thru
roys351, Jan 31, 7:55pm
cost me around $150 all up at horowhenua radiator services levin
jason18, Jan 31, 7:59pm
Oh yeah thats pretty good price! Might give a radiator shop a call tomorrow.
clark20, Jan 31, 8:01pm
jason18, Jan 31, 8:03pm
Oh true. I have a mate at bnt so will call him as well.
jason18, Jan 31, 8:07pm
14 inch be a good size you think!
cuda.340, Jan 31, 8:27pm
buy the biggest single fan with a curved blade you can fit.
pdc1, Feb 1, 8:02am
give Bradley a call at hemi performance in Richmond.(035448106) He runs a radiator shop as well, so I'm sure he will know what he is talking about rather than just selling you anything he has. Check chrysler car parts Nelson listings and you will find stuff they advertise. You could post a question there if you don't want to phone.
toyboy3, Feb 1, 8:23am
what is wrong with the original fan that the car maker put there and has worked well for 35 years ! keeping the engine cool and keeping air passingoverthe exhaust manifold to prevent it from crackingwith excess heat
jason18, Feb 1, 11:11am
I will be running headers and the original fan looks mud
elect70, Feb 1, 1:40pm
I had worked 318with 2fans on my chargeras single woulnt fit .( water pump in the way ) Out of mitsi sigma super saloon& had both run togethercontinously with engine , no AC or trans cooler.
whqqsh, Feb 1, 4:43pm
agree electric fans are often as effective & cool as a monster tach & often less efficient in cooling than the original kit
cuda.340, Feb 1, 5:37pm
i know what you mean. the fan didn't even have a shroud & it's ability to pull air in heavy traffic was crap. you might get lucky & find a jappa fan/shroud combo that fit's your radiator from pickapart otherwise buy the biggest single fan with curved blades you can fit.
bigfatmat1, Feb 1, 7:07pm
maybe cause he wants to and he can who says oem equipment has to stay and is any good specially when we are '35' years down the technology path and things have changed. People can mod their cars if they like. There is always one who thinks car manafacturers know best. Which is absolute bullshit even they get it wrong sometimes or not to perfection.
bigfatmat1, Feb 1, 7:21pm
ya can get pushers and pullers so if ya want to hide it in front you may want to consider this I would not recommend just reversing the polarity of a fan as it becomes less effective have a look at the cfm rating you wont know what the cfm of the original is you will never be able to make ya car run to cold as the thermostat dictates the temp of the engine so bigger is probably better or two smaller ones as mentioned before. You could quite possibly just t a switch in thermo housing or bottom tank pretty easy to wire. I could run ya through that if ya not sure. Oh and most aftermarket ones comewith clips so ya can mount them easy as.
jason18, Feb 2, 7:16am
But how can I fit a gilmour drive an keep the original fan! As I am going to be doing thart as well.
jason18, Mar 1, 12:08am
Cheers man that is the kind of answer I am looking for. Was thinking of front mounting so the engine bay looks cleaner! The davies craig website reckons I will need two fans but unsure
