A lil help please!
kri-kri, Feb 4, 7:09pm
Hi there, need some help does anyone know how much a head gasket would cost for a subi wagon! wanting to get 1 for my partner, itwould be the perfect valentynes present
jono2912, Feb 4, 7:13pm
What type of motor!
twink19, Feb 4, 7:13pm
left or right side
dent, Feb 4, 7:13pm
your wanting to get your partner a subi or a head gasket! What sorta subi
panicky, Feb 4, 7:15pm
what engine EJ20, EJ22, EJ25, Turbo, Non Turbo! what year!Some run multi layer steel head gaskets which are expensive others graphite which are less expensive.
kri-kri, Feb 4, 7:16pm
dunno I do know that its a twin turbo If that helps an its a right hand drive. I know im not helpful, im a girlie girl so I know nothing about cars other then it would make my partner really happy to get his fixed
40wav, Feb 4, 7:20pm
You will need two because it would be false economy to do just one. The gasket is probably the cheap part, replacing them and all the other stuff that is buggered will cost lots lots more.
40wav, Feb 4, 7:21pm
You may as well buy him socks and let him sort his own car.
neo_psy, Feb 5, 6:38am
That's an awesome idea for a Valentines gift though.
Much better than an "I wuv you" teddy bear or such rubbish.
Can't Repco tell from the rego number what the engine is, and therefore what gaskets it needs!
jason18, Feb 5, 6:41am
I would bank on around 2k from memory to do both head gaskets. Thats what I was told a while ago when I looked at buying one.
ginga4lyfe, Mar 12, 3:13am
Buy a Differant NON twin turbo model of Suby for him, it being a twin turbo and most likley open decked block is the reason why it shat its head gaskets so dont fix it, or you will be spending the same amount of money sooner or later because of the same problem, so buy him another Suby, single turbo or less
