Can anybody tell me the spark plug gap and ignition timing for above vehicle
jasongroves,
Dec 15, 3:18pm
Is it the Mazda FE engine! If so, NGK or Bosch gap is 0.8mm, Champion is 1.1mm. If you can give me the engine code I can give you a diagram for the timing.
rimrose64,
Jun 10, 6:04pm
Model No: T38.Engine No: 253609. Hope this helps. Dont Need Valve or cambelt timing, just Ignition timing on bottom pully.
