My key is not working!
1trace, Feb 3, 5:54pm
It looks fine but when I turn it the car does not start. It does click
Do I just need a new one
bendean, Feb 3, 5:56pm
flat battery
fiatracer, Feb 3, 5:57pm
you cant just turn the key, you need to put it into the ignition first
scuba, Feb 3, 6:02pm
so if he fixes the flat battery in the key the car will start!
bendean, Feb 3, 6:03pm
lol car batery but good one
1trace, Feb 3, 6:06pm
So you dont think the key is to worn out, I will try it again
bendean, Feb 3, 6:11pm
if it turns and just clicks your car battery is flat
1trace, Feb 3, 6:12pm
I dont think its an electric car.
1trace, Feb 3, 6:13pm
I put petrol in it, the green one
bendean, Feb 3, 6:14pm
you need a battery to start a car remember lol im a bit slow realisen now ur taking the pis
jason18, Feb 3, 6:20pm
try the car key not the handcuff key
moosie_21, Feb 3, 6:39pm
WIND UP!
ml6989, Feb 3, 8:39pm
Sounds like a jammed or bent Johnson rod. Try releasing it with compressed air and if that fails to kick it into life then you may have to replace it. Be careful if you remove it that you take careful note of which way it is installed as it will fit both ways, but only works one way. One end is magnitised and the other is not.
matarautrader, Feb 3, 8:48pm
It sounds as though you have a polarity conscious key. These must only be used with the left hand as they were originally designed for the American left hand drive market.
1trace, Feb 4, 11:37am
Thanks for all the help but it still does not work.
I even tried a new key today but it must be faulty.
johnf_456, Feb 4, 11:48am
flat battery imho
matthew111, Feb 4, 11:51am
call the AA
icemans1, Feb 4, 12:02pm
not necessarily, ya get the same symptom for dirty starter contacts etc.
johnf_456, Feb 4, 12:07pm
Yea but I say a flat battery is more than likely so more the right answer. But yes you are correct, batterys these day do not last long.
saxman99, Feb 4, 1:00pm
The car is probably a write-off.
bigjerry, Feb 4, 1:30pm
is it a commodore! VR/VS because if it is, i reckon i know the answer.
bigracket, Feb 4, 1:37pm
The little man inside the mota has died !
1trace, Feb 4, 2:40pm
Now you are just being silly
My cars a girl!
1trace, Feb 5, 2:23pm
lol to true!
goslow, Mar 20, 3:52am
Have you tried pushing the big black 710 button on top of the engine!
