Air flow meter to MAP Sensor (CA18DET)
20498, Feb 11, 12:58pm
Is there anyway to change from a Air flow meter on a ca18det to a MAP Sensor without changing the computer over and some how hook up the wiring from the Air flow meter to the MAP sensor!
Cheers.
ginga4lyfe, Feb 11, 1:04pm
if you have enough money, it is possible, but probably pointless
falcon15, Apr 5, 11:18pm
You can get piggy back computers that let you run a map sensor instead of a afm but its a waste of time and money your better off going with a link ecu or somthing similar
