12a rotary timing
jason18, Feb 9, 9:00am
rotahavik.co.nz go there some one should be able to help
321mat, Feb 9, 11:41am
Ahhh, rotary engines. just like communism, both work well, BUT ONLY IN THEORY.
motorway, Feb 9, 11:55am
Brap-Brap-Brap.
saki, Feb 9, 2:31pm
Points or electronic, modifyed !
quickstitch, Feb 9, 4:44pm
i set the timer on my chicken cooker to 1 hour 15 minutes, Comes out perfect every time. sorry, couldn't help myself.
rojakell, Feb 9, 5:04pm
Search the Archives of Ausrotary.
marmatt, Feb 9, 6:18pm
havik blew aseal and will be back in the next week
mk3zephyr, Feb 9, 6:47pm
single or twin dizzy!
rotormotor7, Feb 9, 6:59pm
ausrotary or join up to kiwrotary and search/ask there
saki, Feb 10, 2:45pm
Simple warm engine
you need 2 long plug leads
remove dist cap
conect one lead to leading coil
the other to trailing coil\conect to L & T plugs no 1 rotor (front_
stat engine will take a bit but will run
set leading on the first mark as it goes past the pointer
turn off and loosen the base plate for trailing pickup
restart and move the base plate til the pointer lines up with the pully second mark.
stop reassemble check timing
or you can doe it with the dizzy cap on set leading
check tralling turn off move base plate wrong way start check turn off and on and on
I will probably get pooh poohed for telling you to try and run the engine with cap off but it does work, learnt it of Jon Butler of Manon buttler motors yonks ago.
icemans1, Feb 10, 4:52pm
time to get a V8, boy
marmatt, Feb 11, 5:11am
cap off are you sure , can you get a vid of it !
saki, Feb 11, 2:29pm
No vid I was doing it years ago, Owned and raced 4 different rotary cars
g_k, Feb 11, 3:55pm
must be your cam timing
punkboy, Feb 11, 5:32pm
mmm.! wonder what sort of response this bloke would have got asking about ''350 sb chev ignition timng''.lot more helpfull me thinks.nothing new on TM motoring aye.why this sarcasm,! is it the sound a rotary makes,was your grandad in a japanese POW camp ! sure im all for a laugh,banter etc .end of the day its just another internal combustion engine,nuts and bolts. v8 owner myself.whats your opinion.good onya saki for positive feedback.
saki, Apr 6, 12:06pm
It stands to reason that it will run on on the front rotor only with the cap off if the plug leads are set up correctly, when I had my business in Feilding 89-98 I probably tuned about 3-4 a week a lot sent to me from garages in the town and that included Moore Mazda (gone) I never told the mechanics how I did it an easy $100 not only for my time but my knowledge, couldnt tune a chev I cant reach the dizzy.
