Amp/Sub troubles
moosie_21, Feb 6, 7:32pm
Righteo. Have a Sony 12' sub and amp. Sub keeps cutting out when turning, and finally gave up totally this weekend. Chekced all wires, seem fine, nothing loose. Amp has been known to overheat since it cannot handle the power the sub needs, but give it a little cool down time and it is fine. Have also checked motherboard of amp for scorching, nothing there. I'm kind of stumped. Was thinking of getting another amp and hooking it up to the sub to see if that is the problem! Any other suggestions! TIA
jono2912, Feb 6, 7:34pm
Turning the car.!
moosie_21, Feb 6, 7:36pm
lol, yup. If I go to turn it cut out sometimes, then when I turned again it would come back. That's what made me check the wiring.
jono2912, Feb 6, 7:39pm
Seems weird, haven't come across is before. Do you have electric power steering!
jasongroves, Feb 6, 7:41pm
Turn the gain down for a start to stop the over heating and give the amp some breathing space.get a fan if you need to.
I would check all the wiring again, including RCAs as they could be faulty.
Remove each wire from the sub and amp individually and inspect, cut and re-strip if necessary making sure all connections are firm when re-installing.
moosie_21, Feb 6, 8:29pm
Was considering just getting another amp to match the RMS of the sub so it won't be overloaded all the time. It was overheating even with the gain lower. It does have space, just no fan, which never helps!
I have stripped, reconnected and tightened all wires. Don't know how to check RCA's since they are plug-ins. It has me rather stumped, but I'm 95% sure it's the wiring.
directorylist, Feb 6, 8:38pm
Get a multimeter :)
siren676, Feb 6, 9:03pm
Does it matter which way you are turning! Could the steering rack be messing with the main +ve wire!
74nova, Feb 7, 5:11am
the amp wont 'overload' driving a speaker rated higher than the amp. It just wont run it very load. unless its a dual voice coil sub and its wire 2ohm bridged on the amp. sounds like there is a short somewhere.
moosie_21, Feb 7, 9:04am
Yes it has been bridged, don't know if it's dual voice coil however.
johnf_456, Feb 7, 9:12am
Dry solder joint!
moosie_21, Feb 7, 10:28am
The sub used to stop, then sometimes cut back in when turning again. Will check wires again tonight.
jono2912, Feb 7, 12:46pm
Be specific. What part of car/audio setup!
moosie_21, Feb 7, 3:53pm
I'm guessing he's talking about the +'ve and -'ve on the sub. Yes it is dry, don't know why it would be wet.!
cwlinney, Feb 7, 4:43pm
lol, you're kidding! Prob remote (usually the thin blue wire) at back of head unit. Check back of headunit and get back to us
johnf_456, Feb 7, 4:47pm
Considering we are talking about an amp what else would I talk about. An amp lol
http://www.pcuser.com.au/pcuser/hs2.nsf/lookup+1/2BA1DD3A7AF26E20CA256F2500358412
quote : It might also be sensitive to vibration or movement.
Hence the whole turning thing.
Have you checked the remote turn on and everything else with a test lamp or multi meter.
moosie_21, Feb 7, 4:59pm
lol, my bad. Don't have access to multimeter or test lamp unfortunately.
I shall check the remote turn on soon. Have had trouble with it from the headunit before.
johnf_456, Feb 9, 3:22pm
Update!
moosie_21, Feb 9, 6:11pm
Sorry, been really busy. Will try and get round to it tomorrow and keep you all updated
richard198, Feb 10, 12:48pm
Dry solder joint means not connecting. Is everything including amp screwed down tight! Check, check and check again. (inculding the wiring between head and amp) Assume nothing!
jono2912, Feb 10, 1:51pm
Well, if we're talking about the amp. It could be any one part of the amp, internal or external connection points, (there are many) it could of also been the sub, headunit, and any other part of the car (in relation to the audio setup), since that is what the amp is attached to. Judging by the reaction of the OP to your question, I assume you may need to be a little more specific.
johnf_456, Feb 10, 1:53pm
Quote from first post : Amp has been known to overheat
Dry solder joint also get worse with heat, then mentioned the movement. When he mentions SPECIFICALLY the amp is over heating and the AMP is the issue what else would it be. The op does not know about dry solder joint so trying to get them work it out is beyond them no offence op.
jono2912, Feb 10, 1:56pm
So that means everything else is presumed not to have dry joints! I'd be out of work if I always assumed that.
And I'm pretty sure nothing is beyond explaining to the OP. Surely people still know how to learn.
johnf_456, Feb 10, 1:57pm
Going by what I have read, they have checked all the wiring etc. I didn't say it WAS just one possible thing to look at it upon investigation. Has dry joints do not like movement and heat.
moosie_21, Feb 12, 3:41pm
Turns out the REM cable was not plugged in properly to the constant power source behind the headunit and was only barely touching, hence why it was fading in and out around corners. Cheers everyone!
