WOF. Hay traders could someone please tell me what u need to pass a wof so i can do a at home check before i take it in
nvabeenthre,
Dec 24, 6:23am
Hay traders could someone please tell me what u need to pass a wof so I can do a at home check before I take it in
andrea_w,
Dec 24, 6:29am
lmao this has to be a wind up thread.
kevymtnz,
Dec 24, 6:32am
1st thing you do is go outside n see if it is still there and not been stolen
morrisman1,
Dec 24, 6:41am
if you're going to do a home check before just do the things like lights all working, exhaust not leaking, tyres all at least 1.5mm thread depth, spare bolted in and check for rust if that could be a factor on your car.
You can download the VIRM which has full details of the WOF inspection, just google it
pup2,
Dec 24, 6:47am
a car
Dec 24, 6:59am
LMAO there is far more things that a vehicle has to comply to that can be covered in a brief thread on here, it takes a hell of a lot longer than five minutes to explain.Leave it up to the inspector and fix what gets failed unless you want to spend several hours reading the eVIRM and probably still not understanding much of it.
wheeler1,
Dec 24, 7:22am
best advise I can give is to check all the lights tyres etc as above but also take it clean .For example dont leave the seatbelt jammed behind the seats covered in a foot of dog hair and drool ,remove the dirty knappies that have been there for a month ,fill the washer bottle cause my workshop is not the only place with water some one else add their things
toyboy3,
Dec 24, 7:46am
remove the golf clubs from the bootso the car can be inspected
ozz1,
Dec 24, 9:08am
3 screaming kids in the back. used to work a treat
big.b-lil.c,
Dec 24, 10:47am
take it for a service and pre wof check with a MECHANIC not a back yarder.
tonyrockyhorror,
Dec 24, 10:54am
Why would you bother to get someone else to do a pre-WoF check that will cost you when you get a free 28-recheck! And why would you go to any non-'backyarder' mechanic that doesn't have a WoF ticket!
Dec 24, 10:57am
It doesn't actually, as they all have to be out of the car, along with kiddy seats.
saffa2,
Dec 24, 11:00am
What size bales!.
beblowin,
Dec 24, 12:00pm
skateboards dont need a wof but they do need servicing every 100kms LOL
sandypheet,
Dec 24, 12:06pm
This time of year a box of piss will do.
triangle1,
Dec 24, 2:06pm
Make sure the tyres are not flat.
gabbysnana,
Dec 25, 5:22pm
Arent you doing a re-register, I would have thought the WOf would be the least of your worries!
duanz,
Dec 25, 5:27pm
omg this cud be a long day for you.
basics are lights tyres oil leaks seat belts RUST any they find they will slap you for. brakes/hand brake include ball joints/wheel bearings/steering rack etc, bascially any part that moves under the car will be checked over by at least 3 mechanics in vtnz. windscreen-crack free door hinges for rust thats a rough list too get you started, but throw it in for a wof check they give you 28days for a pre check so want cost you a cent
good luck
also what one mechanic will fail you on can differ too the next soo just becoz you get it checkd at your local garage doesnt means its guna fly thru vtnz
marcos1,
Jul 9, 2:46am
You just repeated a previous post.
Did you not read the thread!
