Cigarette Smell
bashfulbro, Dec 26, 6:28pm
Can anyone recommend a good product that is sprayed into the air conditioning of a car to get rid of the smoke stink !, There are a few on the market, anyone tried one that`s good !.Thanks
kaituna, Dec 26, 6:32pm
Change the intake air filter under the windscreen.
alan1111, Dec 26, 6:49pm
Cabin Filter its called. Not all cars have them though. What sort of vehicle do you have !
xs1100, Dec 26, 6:50pm
theres a uv light that most car dealers have thats ment to work
mugenb20b, Dec 26, 6:52pm
Ozone machine.
cuda.340, Dec 26, 7:03pm
with a garden style pressure sprayer, fill with a cleaning agent e.g. eucalyptus degreaser, & spray the a/c box thru the plactic ducts connected at the side. the excess rinsing liquid should drain out under the car. just make sure you are squirting away from the fan motor.
tgray, Dec 26, 7:30pm
The smoke smell is usually in the floor mats.
Give them the 'sniff test' and then throw them out.
Then sprinkle 'shake n vac' all over the seats and floor, but DON'T vacuum! Instead, bang to disperse with the palm of your hand. Good luck.
bashfulbro, Dec 26, 8:42pm
This particular one is a Toyota Caldina, older one, .95
bashfulbro, Dec 26, 8:43pm
thanks everyone for your help.
kazbanz, Dec 27, 11:32am
bashfull--is the smoke stink specifically in the ac system or is it a general stink in the cabin!
unbeatabull, Dec 27, 1:39pm
You can run a De-Oderiser through the A/C/Heater system, we use them at work, basically a machine that expels a misty smoke that smells good, have the heater on Recirc and place the exit tube of the machine by the fan pickups usually under the dash and it circulates it around the car.
kazbanz, Dec 27, 1:42pm
UB---which is all well n good but if the smell is in the head lineing thats kinda pointless
bashfulbro, Jul 25, 11:44am
There is a general smoke stink when first getting in, but is a bit worse when AC is on
