Vs commy backfireing
2much.hp, Feb 13, 7:17pm
i have a vs ser2 that started as just a miss under load then turned into a continual miss and now is backfireing as well
have done a comprestion test and all lungs are over 200psi
running real ritch
has a heat problem as well and is running hot, it has a new water pump and a cooler thermastat but is still getting hot
when running can unplug injector for #2 and dosnt change a beat so must be problem with #2 but if it was the injector was jamed open how is it backfireing
any idears
im_andrew, Feb 13, 8:50pm
Check your plugs and leads for corrosion. If not, coilpacks or DFI modual.
Fairly common fault, have had this happen on both of mine.
2much.hp, Feb 14, 10:45pm
new plugs and leads on aswell sorry forgot to menchion
if it was the crank angle sensor that would lead to back fireing looking it the intake chambor its only the #1 or #2 or both that are backfireing but shouldent they all be back fireing!
also it has the running rich problem now that could be related! and makeing it run hot!
sooseque, Apr 20, 3:44am
yes i get what you are trying but i dont know the A to your Q
