is a r34 rb25det neo motor going to bolt up to a gtst gearbox using a gtst flywheel and clutch i keep hearing different story and the shop saying no (gtst gbox flywheel out of r32)
1ollie,
Feb 16, 8:51am
Yes if you use the R32 gearbox, flywheel and clutch it will work also yes the gearbox bolts up to the motor and yes the flywheel bolts to the motor. People telling you it wont work will be getting confused, its if your using the NEO gearbox you need the flywheel & clutch to suit it because they are a pull type clutch and not a push type like all the earlyer models.
jsbike,
Feb 16, 8:58am
change the shop you go to, they are wrong.
antiri,
Feb 16, 9:51am
cheers guys that wat i was thinking
