Gti-R Help
callum34, Feb 16, 6:13pm
hey guys i need a little help i have a gti-r pulsar and have just upgraded my standard t28 turbo to a t3t4 and i want to know some things.
1.will i need to upgrade my standard fuel pump!
2.how much boost will i be able to run on a standard engine!
cheers
andrea_w, Feb 16, 6:29pm
They run a T25 standard as far as I know ;)
1) More than likely, depends on the tune
2) Depends on the tune.
T3/T4 means sweet FA too, it only describes the frame. The internals of a T3/T4 can vary, a LOT!
1fordluva, Apr 25, 4:45pm
Yes and a good aftermarket fuel prssure regulator.
Dont know how much they normally run,wouldnt go past 12psi with that turbo.
Would be wise to get afr and detonation checked on the dyno while on boost also,better that than a lunched engine.
